NetApp Knowledge Base
SnapCenter HANA database autoconfig entries turn "Deleted" when DAA is added
146
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
SnapCenter Plug-in for HANA (SCHANA) 4.3 to 4.3.1
Issue
When adding the HANA Diagnostic Agent, which creates it's own "DAA" tenant under the System Database, is installed, any re-discovery will turn the original autoconfig HANA database entry into a deleted entry, showing the following error in the HANA job log:
Multiple instances (DAA,<SID>) of HANA is detected on this host and the auto discovery is not supported for this configuration. You must manually add this instance to SnapCenter Server.
New to NetApp?
