SnapCenter 6's Oracle Applications plug-in fails to quiesce Oracle database on Unix
Applies to
- SnapCenter "Oracle Applications" plug-in (ORASCPM)
- SnapCenter 6.0 and higher
Issue
During the quiesce operation in a backup, the process fails with exit code 1, and the Job Details say:
SCC-00164: Application quiesce for the plug-in [ORASCPM] failed with exit code [1] and with error : (DATE-TIME) Quiescing databases(DATE-TIME) Quiescing database <ORASID>(DATE-TIME) Verifying correct version of database <ORASID>(DATE-TIME) Executing external sql script [/var/opt/snapcenter/scc/UxavrfhEjA.sc] for database <ORASID>(DATE-TIME) Exeecuting SQL sequence:(DATE-TIME) connect / as sysdba(DATE-TIME) select * from v$version;(DATE-TIME) exit;(DATE-TIME) Executing external sql script [/var/opt/snapcenter/scc/UxavrfhEjA.sc] for database <ORASID>(DATE-TIME) Command [/bin/su - oracle -c "ORACLE_HOME=/oracle/app/19;ORACLE_SID=<ORASID>;/oracle/app/19/bin/sqlplus /nolog @/var/opt/snapcenter/scc/UxavrfhEjA.sc"] finished with(DATE-TIME) exit code: [1]
