NetApp Knowledge Base
SnapCenter 4.9 and 5.0 install fails with fatal error during installation
3,187
Visibility:
Votes:
3
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter Server (SC) 4.9 and 5.0
  • MySQL Server
Issue
  • SnapCenter upgrade to 4.9 or 5.0; or fresh installation of SnapCenter 4.9 or 5.0 fails returning GUI fatal error during installation.
  • MySQLInstaller log error:
InstallShield.log
(CLR Action): GetMySqlConnection: Error: MySQL Exception occured: Threw Exception.Type: Devart.Data.MySql.MySqlException, Exception Error Code: 0x80004005, Exception.Message: Can't connect to MySQL server on 'localhost' (10061):
No connection could be made because the target machine actively refused it 127.0.0.1:3306
(CLR Action): ExecuteNonQuery: Error: MySQL Connection is invalid.
MySQLInstaller_<Date_Time>.log
Install MySQL Server.Log: Installation : Failed to start process for MySQL Server <Version>
Install MySQL Server.Log: Installation : Database initialization failed.
Install MySQL Server.Log: Installation : Configuration of MySQL Server <Version> has completed unsuccessfully! (Check the log for more details)
Install MySQL Server.Log:: ERROR: SET PASSWORD: Exception: Can't connect to MySQL server on 'localhost' (10061):
SMS_Install_<Date_Time>.log
StartService: ERROR Cannot start service: Time out has expired and the operation has not been completed.
WiXCSCA: RestartService: StartService: ERROR: Cannot start MySQL57 service
WixCSCA.ConfigureMySqlServer: MysQL Service restart is failed
MySql: SetMySqlRootPassword: Exception: Can't connect to MySQL server on 'localhost' (10061):
CreateDB: CustomAction1: ERROR : EXCPTION: Unable to start MySQL service: Time out has expired and the operation has not been completed.
  • If accessing the SnapCer UI from the SnapCenter:
SnapCenter repository is not accessible. Error: The Entity Framework provider type 'Devart.Data.MySql.Entity.MySqlEntityProviderServices, Devart.Data.MySql.Entity.EF6 , Version=8.5.658.0, Culture=neutral, PublicKeyToken=09af7300eec23701' registered in the application config file for the ADO.NET provider with invariant name 'Devart.Data.MySql' could not be loaded. Make sure that the assembly-qualified name is used and that the assembly is available to the running application. See http://go.microsoft.com/fwlink/?LinkId=260882 for more information.
  • If accessing the SnapCenter UI from another computer:
Runtime Error
New to NetApp?
