NetApp Knowledge Base
SMBR initiated snapshot mount operations fail with error: "Mount-SdSnapshot failed"
1,574
Visibility:
Votes:
0
Category:
single-mailbox-recovery-smbr
Specialty:
snapx
Last Updated:
Applies to
  • Single Mailbox Recovery (SMBR)
  • SnapCenter Server
Issue
SMBR initiated snapshot mount operations from SnapCenter backups fail with error, "Mount-SdSnapshot failed".
The entries in the SnapShotManager.log file (default path C:\ProgramData\NetApp\SMBR\Logs\) show the following error:
ERROR ao - Command execution error: FullyQualifiedErrorId: 102,SnapDrive.Client.PSModule.MountSdSnapshotException message: Failed to mount the Snapshot copy.Failed to mount the resource: <lun_path> from snapshot: <snapshot>.
Possible Resolution: Make sure that Host to storage connectivity is available.
The corresponding entries in the SnapDriveSALDebug.log (default path C:\Program Files\NetApp\SnapCenter\SMCore\) show that no iGroup information is discovered:
Error SAL PID=[5528] TID=[9388] No Igroup information found for the specified input
Verbose SAL PID=[5528] TID=[9388] Retrieval of IGroup information-successful
Verbose SAL PID=[5528] TID=[9388] --IgroupManagementServiceProvider::GetIgroup
Error SAL PID=[5528] TID=[9388] No initiator Groups found in the host <host>
Verbose SAL PID=[5528] TID=[9388] exception 'No initiator Groups found in the host <host>' caught
Error SAL PID=[5528] TID=[11888] Snap connect failed - [Resource: <lun_path>]
Error SAL PID=[5528] TID=[11888] Failed to mount the resource: <lun_path> from snapshot: <snapshot>.
Error SAL PID=[5528] TID=[11888] Failed to mount the Snapshot copy.Failed to mount the resource: <lun_path> from snapshot: <snapshot>.
New to NetApp?
