NetApp Knowledge Base
SCW installation failure - Failed to Bind the port with SSL certificate
70
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter plugin for Windows (SCW)
  • Windows Server 2022
  • HTTP/3
Issue
  • SCW plugin installation failure due to error shown in the SnapCenter Server - InstallShield Wizard:
 Failed to Bind the port with SSL Certificate.
  • The corresponding SMCore_Install log shows an error when attempting to create the port binding with the SSL certificate:
WIXCSCA: BindPortSSLCertificate: GenericProcessFn_Execute: Execution Command: netsh http add sslcert ipport=0.0.0.0:8145 certhash=<CERTIFICATE_THUMBPRINT> guid=<GUID#>
WIXCSCA: BindPortSSLCertificate: GenericProcessFn_Execute: Execution Output:
WIXCSCA: BindPortSSLCertificate: GenericProcessFn_Execute: Execution Output: SSL Certificate add failed, Error: 1
WIXCSCA: BindPortSSLCertificate: GenericProcessFn_Execute: Execution Output: Incorrect function.
WIXCSCA: BindPortSSLCertificate: GenericProcessFn_Execute: Process successfully executed.
WIXCSCA: BindPortSSLCertificate: Validate the port binding with our certificate.
WIXCSCA: BindPortSSLCertificate: GenericProcessFn_Execute: Execution Command: netsh http show sslcert ipport=0.0.0.0:8145
WIXCSCA: BindPortSSLCertificate: GenericProcessFn_Execute: Execution Output: SSL Certificate bindings:
WIXCSCA: BindPortSSLCertificate: GenericProcessFn_Execute: Execution Output: -------------------------
WIXCSCA: BindPortSSLCertificate: GenericProcessFn_Execute: Execution Output: The system cannot find the file specified.
WIXCSCA: BindPortSSLCertificate: GenericProcessFn_Execute: Execution Output: Process successfully executed.
WIXCSCA: BindPortSSLCertificate: Port binding validation failed. Aborting the installation.
ERROR: Failed to Bind the port with SSL Certificate.
  • The Windows System Event Viewer log shows Event ID 36871:
A fatal error occurred while creating a TLS server credential. The internal error state is 10013. The SSPI client process is SYSTEM (PID: 4).
New to NetApp?
