SCV replication failure - unable to find snapshot on primary volume
Applies to
SnapCenter Plugin for VMware (SCV)
Issue
- SCV fails to update a SnapVault relationship due to an error indicating the snapshot is not present on the primary storage controller volume despite the snapshot being present on the volume at the time of the error.
Job-XXXXXX.logReplicationInformation - Storage : <PRIMARY_SVM_NAME/IP>, Volume : <VOLUME_NAME> Snapshot : <SNAPSHOT_NAME>Begin GetSnapshotBegin GetConfigSettingSnapshotDiscoverMaxRetryFileExistBegin GetSALPluginProviderBegin GetStorageSystemIdBegin GetStorageSystemIdFromCacheSVM: <PRIMARY_SVM_NAME/IP>Looking up SAL plugin provider for StorageSystemOSType: DataOntap.Begin GetSALPluginProviderEnd GetStorageSystemIdFromCacheBegin GetStorageSystemIdFromCacheUserOperationcontext: Name: , GroupName:, Domain:, RoleId:0, Role Shared:False, UserGroup ObjectType:None, IsAdmin: False, GroupId:Connecting to Storage system id: <PRIMARY_SVM_NAME/IP>End GetStorageSystemIdFromCacheEnd GetSALPluginProviderBegin GetResourceBegin IsForceZAPIBegin GetSALPluginProviderCreating connection parameters$SnapName: <SNAPSHOT_NAME>Begin GetSALRunCommandMaxRetryEnd RunCommandinvoking command-doneEnd GetSALPluginProviderThe result from get-ncsnapshot is null/emptySVM: <PRIMARY_SVM_NAME/IP>End GenerateGetSnapshotResultINFO: Retry interval snapshot discover config setting not found.(1/2) SnapshotDiscoverRetryInterval=3000 ms......Begin GetConfigSettingSnapshotDiscoverRetryIntervalEnd GetSnapshotEnd GetConfigSettingSnapshotDiscoverRetryIntervalINFO: Retry interval snapshot discover config setting not found.$SnapName: <SNAPSHOT_NAME>(2/2) SnapshotDiscoverRetryInterval=3000 ms......$SnapName: <SNAPSHOT_NAME>Begin IsForceFsxEnd GetSALRunCommandRetryIntervalBegin IsForceZAPICommand: Get-NcSnapshot Force ZAPI: trueConfig override, Use ZAPIinvoking command-doneIs REST supported for the command: FalseErrorCode (-1), ErrorMessage (Unable to find Snapshot (<SNAPSHOT_NAME>) on volume (<VOLUME_NAME>) from storage (<SVM_NAME/IP>))
