NetApp Knowledge Base
SCV fails to remove and edit cluster if the cluster name ends with "-mc"
113
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Plug-in for VMware vSphere(SCV)
  • ONTAP cluster name ends with "-mc"
Issue
  • SCV fails to remove the cluster in Storage Systems by the following error:
Failed to remove storage system information: Validation failed:
 -- StorageConnections[0]: The specified name Name : [<CLUSTER_NAME>]
 does not exist or can not be modified.
  • SCV fails to edit the cluster in Storage Systems by the following error:
Failed to get storage system information.
No Storage System found for selected vCenter
  • vmcontrol.log indicates that removing cluster fails by Validation failed
ERROR scv1 --- [tp1825027294-19] c.n.a.s.c.SnapManagerStorageServiceImpl  : [JobId:0] Failed to remove storage system information: Validation failed:
 -- StorageConnections[0]: The specified name Name : [cluster-mc]
DEBUG scv1 --- [tp1825027294-19] c.n.a.r.v.c.s.SvmJsonController          : Error occured while adding storage system. Failed to remove storage system information: Validation failed:
  • ProtectionService.log indicates that Validation failed is detected in FluentValidation.ValidationException
[ERR] [Storage] [TID:25] [RID:0HMOJP4BADIO1:00000002] [CID:] [JID:] FluentValidation.ValidationException: Validation failed:
New to NetApp?
