SCV does not rotate backup Snapshots with retention due to insufficient free memory
Applies to
- SnapCenter Server 4.1.1
- SnapCenter Plug-in for VMware vSphere (SCV) 4.1.1
Issue
- SCV backup Snapshots are not deleted by retention.
SMCore_<JOB_ID>.logshowsRegisterBackupsgetsInternal Server Error (500)in the taskRegistering Backup and Applying Retention.
INFO SMCore_<JOB_ID> PID=[<PID>] TID=[<TID>] Activity - Registering Backup and Applying Retention, Starting
DEBUG SMCore_<JOB_ID> PID=[<PID>] TID=[<TID>] RegisterMetadataActivity Started
DEBUG SMCore_<JOB_ID> PID=[<PID>] TID=[<TID>] RemoteUrl: https://<SNAPCENTER_SERVER_URI>:8146/BackupMetadataService.svc/RegisterBackups
INFO SMCore_<JOB_ID> PID=[<PID>] TID=[<TID>] SmWebClient : webRequest.ServicePoint.ConnectionLimit set to 1500
ERROR SMCore_<JOB_ID> PID=[<PID>] TID=[<TID>] WebException in method: Invoke.
System.Net.WebException: The remote server returned an error: (500) Internal Server Error.
at System.Net.WebClient.UploadDataInternal(Uri address, String method, Byte[] data, WebRequest& request)
at System.Net.WebClient.UploadString(Uri address, String method, String data)
at SnapMgrHelper.RestAdapter.Invoke[TReq,TRes](TReq request, String methodType, String remoteUrl, Boolean dataContractSerializer, Boolean isAuthorized, Boolean logRequest, Boolean logResponse)
Additional information:
DEBUG SMCore_<JOB_ID> PID=[<PID>] TID=[<TID>] Invoked service successfully
ERROR SMCore_<JOB_ID> PID=[<PID>] TID=[<TID>] Exception in method: Execute.
at SnapMgrHelper.SmsRestHelper.Invoke[TReq,TRes](String methodType, TReq request, String serviceName, String method, Boolean xmlContentType)
at SnapMgrCoreService.Workflows.Common.Backup.RegisterMetadataActivity.Execute(SmWorkflowContext workflowContext, SmRequest request) : Detailed Exception The remote server returned an error: (500) Internal Server Error. : BaseException System.Net.WebException: The remote server returned an error: (500) Internal Server Error.
ERROR SMCore_<JOB_ID> PID=[<PID>] TID=[<TID>] ErrorCode (-1), ErrorMessage (The remote server returned an error: (500) Internal Server Error.)
DEBUG SMCore_<JOB_ID> PID=[<PID>] TID=[<TID>] RegisterMetadataActivity Done
SnapManagerWeb_<JOB_ID>.logshows the taskRegistering Backup and Applying Retentionis failed.
DEBUG SnapManagerWeb_<JOB_ID> PID=[<PID>] TID=[<TID>] Updating the job (<JOB_ID>) task (Registering Backup and Applying Retention) status as Failed
Application event logindicates the following error message. The service '/BackupMetadataService.svc' cannot be activated due toSystem.InsufficientMemoryException.
WebHost failed to process a request.
Sender Information: System.ServiceModel.ServiceHostingEnvironment+HostingManager/10501549
Exception: System.ServiceModel.ServiceActivationException: The service '/BackupMetadataService.svc' cannot be activated due to an exception during compilation.
The exception message is: Memory gates checking failed because the free memory (XXXXXXXXX bytes) is less than 5% of total memory. As a result, the service will not be available for incoming requests.
To resolve this, either reduce the load on the machine or adjust the value of minFreeMemoryPercentageToActivateService on the serviceHostingEnvironment config element..
---> System.InsufficientMemoryException: Memory gates checking failed because the free memory (XXXXXXXXX bytes) is less than 5% of total memory. As a result, the service will not be available for incoming requests.
at System.ServiceModel.Activation.ServiceMemoryGates.Check(Int32 minFreeMemoryPercentage, Boolean throwOnLowMemory, UInt64& availableMemoryBytes)
at System.ServiceModel.ServiceHostingEnvironment.HostingManager.CheckMemoryCloseIdleServices(EventTraceActivity eventTraceActivity)
at System.ServiceModel.ServiceHostingEnvironment.HostingManager.EnsureServiceAvailable(String normalizedVirtualPath, EventTraceActivity eventTraceActivity)
--- End of inner exception stack trace ---
at System.ServiceModel.ServiceHostingEnvironment.EnsureServiceAvailableFast(String relativeVirtualPath, EventTraceActivity eventTraceActivity)
Process Name: w3wp
Process ID: <PID>
