NetApp Knowledge Base
SCV backup job fails by "Unable to quiesce on SCV" due to VI SDK invoke exception
959
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
SnapCenter Plug-in for VMware vSphere (SCV) 4.3.1
Issue
  • SCV backup job fails with message "Unable to quiesce on SCV".
Task 'Quiescing Applications' failed with error: Unable to quiesce on SCV: Exception occurred when quiescing virtual machines: <VM_NAME>.
  • vmcontrol_<JOB_ID>.log shows CreateSnapshot_Task detects exception "VI SDK invoke exception:java.net.SocketTimeoutException: connect timed out".
DEBUG <HOST> --- [ol-114-thread-1] c.n.a.b.QuiesceManager                   : Getting VM Snapshot Name: <VM_SNAPSHOT_NAME>
DEBUG <HOST> --- [ol-114-thread-1] c.n.a.b.QuiesceManager                   : VM [<VM_NAME>] is powered ON. Taking VMware snapshot with name: <VM_SNAPSHOT_NAME>
DEBUG <HOST> --- [ol-114-thread-1] c.n.a.v.VsphereInventoryService          : Looking for VM with instance UUID <UUID>
DEBUG <HOST> --- [ol-114-thread-1] c.n.a.v.VsphereService                   : [JobId:<JOB_ID>] Connecting to vSphere with session <SESSION_ID>
DEBUG <HOST> --- [ol-114-thread-1] c.n.a.v.VsphereInventoryService          : [JobId:<JOB_ID>] found the VM <VM_NAME> VirtualMachine:vm-XXXX @ https://<VCENTER_HOST>:443/sdkwith instance uuid found <UUID>
DEBUG <HOST> --- [ol-114-thread-1] c.n.a.v.VsphereService                   : VsphereUtils: Monitoring Task CreateSnapshot_Task
 WARN <HOST> --- [ol-114-thread-1] c.n.a.v.VsphereSnapshotService           : [JobId:<JOB_ID>] Got Exception while creating snapshot '<VM_SNAPSHOT_NAME>' : java.rmi.RemoteException: VI SDK invoke exception:java.net.SocketTimeoutException: connect timed out
  • Exception "VI SDK invoke exception:java.net.SocketTimeoutException: connect timed out" can be also seen in vmcontrol_jetty_server.log.
INFO  SCV root java.lang.RuntimeException: java.rmi.RemoteException: VI SDK invoke exception:java.net.SocketTimeoutException: connect timed out
INFO  SCV root     at com.vmware.vijava.vim25.mo.ManagedObject.retrieveObjectProperties(ManagedObject.java:158)
INFO  SCV root     at com.vmware.vijava.vim25.mo.ManagedObject.getCurrentProperty(ManagedObject.java:179)
INFO  SCV root     at com.vmware.vijava.vim25.mo.Task.getTaskInfo(Task.java:62)
INFO  SCV root     at com.netapp.aegis.vsphere.VsphereService.waitForTaskCompletion(VsphereService.java:149)
INFO  SCV root     at com.netapp.aegis.vsphere.VsphereSnapshotService.createSnapshot(VsphereSnapshotService.java:48)
INFO  SCV root     at com.netapp.aegis.backup.QuiesceManager.quiesceVM(QuiesceManager.java:205)
INFO  SCV root     at com.netapp.aegis.backup.QuiesceManager$1.run(QuiesceManager.java:122)
INFO  SCV root     at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
INFO  SCV root     at java.util.concurrent.FutureTask.run(FutureTask.java:266)
INFO  SCV root     at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
INFO  SCV root     at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
INFO  SCV root     at java.lang.Thread.run(Thread.java:748)
INFO  SCV root Caused by: java.rmi.RemoteException: VI SDK invoke exception:java.net.SocketTimeoutException: connect timed out
INFO  SCV root     at com.vmware.vijava.vim25.ws.WSClient.invoke(WSClient.java:101)
INFO  SCV root     at com.vmware.vijava.vim25.ws.VimStub.retrieveProperties(VimStub.java:73)
INFO  SCV root     at com.vmware.vijava.vim25.mo.PropertyCollector.retrieveProperties(PropertyCollector.java:107)
INFO  SCV root     at com.vmware.vijava.vim25.mo.ManagedObject.retrieveObjectProperties(ManagedObject.java:155)
INFO  SCV root     ... 13 more
  • Error message "Unable to quiesce on SCV" can be found in wfe_<JOB_ID>.log.
DEBUG <HOST> --- [     Thread-111] c.n.w.u.LogHelper                        : Starting Quiesce activity
DEBUG <HOST> --- [     Thread-111] c.n.w.r.SCVBackupServiceImpl             : Quiesce on SCV
DEBUG <HOST> --- [     Thread-111] c.n.w.r.u.RestClientUtil                 : Connecting to scv url: https://localhost:8144/scbr/smcoreplugin/quiesce
ERROR <HOST> --- [     Thread-111] c.n.w.r.SCVBackupServiceImpl             : Unable to quiesce on SCV: Exception occurred when quiescing virtual machines: <VM_NAME>.Please check 'Create virtual machine snapshot' task on vSphere Web Client or SnapCenter Plug-in for VMware vSphere logs for detailed error message.
New to NetApp?
