NetApp Knowledge Base
SCV: No SVMs are discovered when adding ONTAP cluster to Storage Systems
105
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Plug-in for VMware vSphere (SCV)
  • FORCE_ZAPI enabled
  • ONTAP 9.14 and later
Issue
  • When adding an ONTAP cluster to Storage Systems in SCV, the cluster is added, however the display name is blank, and no SVMs on the cluster are discovered.
  •  Attempting to edit or delete the cluster fails with the following error message being displayed:
Failed to remove storage system information: An exception was thrown while attempting to evaluate a LINQ query parameter expression. See the inner exception for more information. To show additional information call 'DbContextOptionsBuilder.EnableSensitiveDataLogging'.Failed to remove storage system information: An exception was thrown while attempting to evaluate a LINQ query parameter expression. See the inner exception for more information. To show additional information call 'DbContextOptionsBuilder.EnableSensitiveDataLogging'.
New to NetApp?
