NetApp Knowledge Base
SCV Management Dashboard UI errors after upgrading from 4.9 to 5.0P1
266
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
SnapCenter Plug-In for VMWare 5.0P1 (SCV)
Issue
  • After upgrading SCV to 5.0P1 and logging on to the SCV Management UI https://SCV_IP_ADDRESS_OR_FQDN:8080, the dashboard shows the error:
Vcenter Plugin connection has failed. Invalid credentials found:
  • When re-applying the password to the Configuration section of the dashboard, the error Invalid parameter appears.
  • When trying to disable and re-enable the SCV Service, the error code 400263 appears:
SCV Service
  • You may also observe the port is not valid  error message:
New to NetApp?
