NetApp Knowledge Base
SCV 4.8 upgrade shows curl error: malformed JSON string
2,154
Visibility:
Votes:
1
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Plug-in for VMware vSphere (SCV) 4.8
  • SCV is upgraded from 4.4 or earlier
Issue
  • Upon logging into the maintenance console after an upgrade to SCV 4.8, the user is prompted again to enter the password for the 'maint' user:
We trust you have received the usual lecture from the local System Administrator. It usually boils down to these three things:
    #1) Respect the privacy of others.
    #2) Think before you type.
    #3) With great power comes great responsibility.
[sudo] password for maint:
  • After providing the password for the 'maint' user, the following error is returned:
sudo: curl: command not found
malformed JSON string, neither array, object, number, string or atom, at
character offset 0 (before “(end of string)”) at /home/maint/scripts/get-token.pl line 11.
  • The same "curl: command not found malformed JSON string" error is returned when attempting to access other menus in the maintenance console
  • Command curl -V indicates curl is not installed
$ sudo curl -V
New to NetApp?
