SCSQL volume clone create failed, Exception: Failed to create the volume clone
Applies to
SnapCenter plugin for SQL (SCSQL)
SnapCenter plugin for Windows(SCW)
Issue
- SCSQL clone fails with error "
mount snapshot failed Failed to mount storage resource, error is Failed to create the volumeclone,Object reference not set to an instance of an object" - SnapCenter Clone fails due to volume clone API to Storage is failing at PowerShell module
