NetApp Knowledge Base
SCSQL fails to backup with error "Could not find storage for any of the resources" right after host reboot.
970
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Server 4.1.x
  • SnapCenter Plug-in for Microsoft SQL Server (SCSQL) 4.1.x
  • SnapCenter Plug-in for Microsoft Windows (SCW) 4.1.x
Issue
  • SCSQL backup fails right after SCSQL/SCW host reboot.
  • SMCore.log reports the following error.
Activity 'Creating Snapshot copy' failed with error: Could not find storage for any of the resources
  • SnapDriveSALDebug.log reports the following errors.
Verbose SAL PID=[XXXX] TID=[XXXX] InitializeONTAP() throw exception: Object reference not set to an instance of an object.
Error SAL PID=[XXXX] TID=[XXXX] Object reference not set to an instance of an object.  at
SnapDrive.Nsf.Core.Storage.StorageConnection.Initialize(SDStorageSystemId storageSystemId)
Error SAL PID=[XXXX] TID=[XXXX] Failed to connect to storage system <SVM> Object reference not set to an instance of an object.
  • Windows Application Event Log reports the following error.
SourceName: SnapDriveEventMsgs
EventCode: 528
Message: "SnapDrive failed to set your storage system connection.
Error code : -1
Details : Failed to connect to storage system .
Possible solutions :
1. Check if the firewall blocks the connection.
2. Make sure the Net.Tcp Port Sharing Service is up and running.
3. The credentials are specified correctly."
New to NetApp?
