SCO shows CROSSCHECK errors in RMAN output when pruning the archive logs
Applies to
- SnapCenter Plug-in for Oracle (SCO)
- Oracle 19c RMAN
Issue
During archive log pruning, the process gives a Warning due to the following messages from RMAN:
ORACLE-00101: Error executing RMAN command: [DELETE NOPROMPT ARCHIVELOG UNTIL TIME 'SYSDATE-<DAYS>' LIKE '<ARCHIVE_LOG_MOUNT>/%';]. The command returned: RMAN-06207: warning: 1 objects could not be deleted for DISK channel(s) due
RMAN-06208: to mismatched status. Use CROSSCHECK command to fix status
RMAN-06210: List of Mismatched objects
RMAN-06211: ==========================
RMAN-06212: Object Type Filename/Handle
RMAN-06213: --------------- ---------------------------------------------------
RMAN-06214: Archivelog /<ARCHIVE_LOG_MOUNT>/<LOG_PATH>/<LOGSNAME>_<SEQNUM>_<CODE>.arc
