NetApp Knowledge Base
SCO restore fails with ORACLE-10002, 10005 and ORA-12528 TNS Listener errors
1,245
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
SnapCenter Plug-in for Oracle (SCO)
Issue
During the recovery of the restore process, when archive logs are going to be applied, the process fails with:
c.n.o.c.s.d.DatabaseSpecificationService - An exception thrown during the execution of method isRAC and the exception message is
ORACLE-10002: Error received from connection to Oracle database <SID>: Listener refused the connection with the following error:
ORA-12528, TNS:listener: all appropriate instances are blocking new connections
or:
c.n.o.c.s.r.RecoveryService - An exception thrown during the execution of method recover and the exception message is:
ORACLE-10005: Cannot connect to database instance BYRODBX using JDBC connect string jdbc:oracle:thin:SYS/XXXXXXXX@
Error: IO Error: The Network Adapter could not establish the connection.
in the spl_<Job_ID>.log
New to NetApp?
