NetApp Knowledge Base
SCO install/upgrade fails with error "No Java virtual machine could be found from your PATH environment variable"
166
Visibility:
Votes:
1
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter
  • SanpCenter Plug-in for Oracle (SCO)
Issue
When attempting to upgrade or install the SnapCenter Unix based Plug-ins, it fails with the following error:
No Java virtual machine could be found from your PATH environment variable.
You must install a VM prior to running this program.
New to NetApp?
