SCE backups fail with error: Failed to create VSS snapshot Error Code: -2147212538 VSS E PROVIDER VETO
Applies to
- SnapCenter server 6.1P1
- SnapCenter plugin for Exchange 6.1P1
- ONTAP Multi-admin verification
Issue
SCE backups fail with error: Failed to create VSS snapshot [Error Code: -2147212538] [VSS_E_PROVIDER_VETO]
Job's SCE log entries:
ERROR SCE_2603029 PID=[2928] TID=[133] Message : Operation failed [Error code: -2147212538]
DEBUG SCE_2603029 PID=[2928] TID=[133] --VSSRequestor::LoopWaitERROR SCE_2603029 PID=[2928] TID=[133] Message : Failed to create VSS snapshot [Error Code: -2147212538] [VSS_E_PROVIDER_VETO]
DEBUG SCE_2603029 PID=[2928] TID=[133] --VSSRequestor::CreateVssSnapshotERROR SCE_2603029 PID=[2928] TID=[133] Message : Failed to create VSS snapshot [Error Code: -2147212538] [VSS_E_PROVIDER_VETO] [Error Code: -2147212538] [VSS_E_PROVIDER_VETO]
DEBUG SCE_2603029 PID=[2928] TID=[133] --VSSRequestor::BackupDEBUG SCE_2603029 PID=[2928] TID=[133] sceBackupInfoList.Count = 0DEBUG SCE_2603029 PID=[2928] TID=[133] Releasing backup lockERROR SCE_2603029 PID=[2928] TID=[133] Failed to create VSS snapshot [Error Code: -2147212538] [VSS_E_PROVIDER_VETO] [Error Code: -2147212538] [VSS_E_PROVIDER_VETO] Possible solution: Please check if there is adequete space available on the LUNs.
SCWDebug log:
DEBUG NetApp.Ontapi.NaServer PID=[16920] TID=[Pipeline Execution Thread] <netapp version='1.7' xmlns='http://www.netapp.com/filer/admin' vfiler='am-vfileri-01'><lun-destroy> <force>true</force> <path>/vol/exch_am_pref1_002_edb_vol01/0d297534-e93a-4555-b97a-b111f4f79191.aux</path></lun-destroy></netapp>
DEBUG NetApp.Ontapi.NaServer PID=[16920] TID=[Pipeline Execution Thread] <results reason="This operation requires multi-admin verification. To create a verification request use "security multi-admin-verify request create". " status="failed" errno="13001"/>ERROR DataONTAP.C.PowerShell.SDK.NcControllerCmdlet PID=[16920] TID=[Pipeline Execution Thread] API exceptionNetApp.Ontapi.ErrnoException+EAPIERROR: This operation requires multi-admin verification. To create a verification request use "security multi-admin-verify request create". at NetApp.Ontapi.NaApi`1.Invoke(INaServer server) at DataONTAP.C.PowerShell.SDK.Cmdlets.Lun.RemoveNcLun.ProcessRecord(NcController controller)DEBUG SCW PID=[16920] TID=[56] ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: This operation requires multi-admin verification. To create a verification request use "security multi-admin-verify request create". DEBUG SCW PID=[16920] TID=[56] No retry condition match found or max retry reached. Throwing error The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: This operation requires multi-admin verification. To create a verification request use "security multi-admin-verify request create". DEBUG SCW PID=[16920] TID=[56] --PSHelper::RunCommandERROR SCW PID=[16920] TID=[56] Message : Failed to delete the LUN. This operation requires multi-admin verification. To create a verification request use "security multi-admin-verify request create".
