NetApp Knowledge Base
SCE backup fails with error VSS_E_VOLUME_NOT_SUPPORTED_BY_PROVIDER
1,227
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Plug-in for Microsoft Exchange Server (SCE)
  • SnapCenter Server
Issue
  • SCE backup fails with error like below.
Example:
Activity 'Creating Backup' failed with error: Error: Failed to add to snapshot set. [<DRIVE>:\] [Error Code: -2147212530] [VSS_E_VOLUME_NOT_SUPPORTED_BY_PROVIDER] [Error Code: -2147212530] [VSS_E_VOLUME_NOT_SUPPORTED_BY_PROVIDER]
  • Windows Application Event Log reports an error like below before the backup failure.
Example:
2020-04-17T01:01:12.6538514+09:00 Critical SDW PID=[2360] TID=[3720] Error: The credentials for the storage system <SVM> is not configured.  Resolution: Please check if storage system <SVM> is assigned to the user and is resolvable or add an entry to etc/hosts file.
New to NetApp?
