NetApp Knowledge Base
SCE 4.5 and 4.6 UTM retention fails after backup marked as Point In Time
894
Visibility:
Votes:
1
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Server (SC) 4.5 and 4.6
  • SnapCenter Plug-in for Microsoft Exchange Server (SCE) 4.5 and 4.6
  • Up to the minute (UTM) retention
Issue
  • When using SCE, if UTM retention is triggered during a backup job, log snapshot copies (suffix_1) are not getting deleted from ONTAP and NSM database. This issue occurs if the UTM retention is based on days
  • The backup is marked as point in time (PIT) but the Full backup log snapshots (suffix _1) that are outside of desired retention are not deleted
  • The user database volume and SCEBackupInfo folder retention is successful
  • There are no errors shown in the logs but there are entries showing the backup being marked as PIT and the log backup snapshot (no _1 suffix) being deleted:
    <installation_path>\NetApp\SnapCenter\App_Data\log\SnapManagerWeb_<id>.log:
INFO  SnapManagerWeb_225137 PID=[7744] TID=[112] GetUtmLogBackupByDays - Log backup snapshot name is: <snapshot_name_1>, created date is: 11/8/2021 9:01:36 PM,
start date is: 11/8/2021 9:01:36 PM, excluded is: True,  is log folder marked for deletion: True.
DEBUG SnapManagerWeb_225137 PID=[7744] TID=[112] Mark '<snapshot_name_1>' PIT
  • The database snapshot (without the _1 suffix) from the full backup is successfully removed
    <installation_path>\Program Files\NetApp\SnapCenter\SMCore\SnapDriveSALDebug.log:
Verbose SAL PID=[3376] TID=[7080] Command starts: Remove-NcSnapshot -Volume <vol_name> -Snapshot <snapshot_name>
Verbose SAL PID=[3376] TID=[7080] Command completes: Remove-NcSnapshot -Volume <vol_name> -Snapshot <snapshot_name>
New to NetApp?
