NetApp Knowledge Base
SAP HANA resource is marked for deletion and cannot be configured
769
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
SnapCenter Plug-in for SAP HANA (SCHANA) 4.3 and higher
Issue
SAP HANA resource is marked for deletion under the MDC or single container databases, and cannot be configured or deleted.
This usually occurs after an upgrade from SnapCenter Server 4.3 (which introduced autoconfig for HANA) or 4.3.1 to 4.3.2 or higher.
SCC-00155: Auto Discovery for plug-in [hana] failed with error [Multiple instances (<SID1>,<SID2>) of HANA is detected on this host and the auto discovery is not supported for this configuration. You must manually add this instance to SnapCEnter Server.] and exit code [-1]. Exiting.
Note: If the database is actually still present, and Backups were scheduled to run, these will keep running and working.
New to NetApp?
