NetApp Knowledge Base
Running the SnapCenter 6.x Linux Plug-ins as root fails when java 11 is not default
204
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
SnapCenter 6.x Unix Plug-ins (SCU, SCO, SCHANA, SCC)
Issue
  • Every time the SCC or SPL service is restarted, it starts with the older 1.8 java, even though Java 11 was set as default on installation.
  • This causes failures on usage, due to certain functionality requiring Java 11.
  • spl_init.YYYY-MM-DD.log shows JAVA_HOME is updated to java-1.8.0 folder.
SPLD:SnapCenter Plugin Loader is not running
SPLD:DEBUG: OS Type = Linux
SPLD:DEBUG: Getting JAVA_HOME for user root
SPLD:DEBUG: JAVA_HOME set for user root:
SPLD:DEBUG: JAVA_HOME environment variable is not set or invalid for root user
SPLD:DEBUG: Deriving JAVA_HOME from command path set for user root
SPLD:DEBUG: JAVA_HOME obtained for user root using java path: /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.462.b08-2.el8.x86_64/jre
SPLD:DEBUG: Using Java Version 1.8.0_462
SPLD:DEBUG: Value of SKIP_JAVAHOME_UPDATE false
SPLD:DEBUG: Updating properties file with new JAVA_HOME: /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.462.b08-2.el8.x86_64/jre
SPLD:DEBUG: Value of MAXIMUM_ORACLE_DB_FILES 100000
SPLD:Stopping SnapCenter Plugin Loader
SPLD:SnapCenter Plugin Loader is not running.
New to NetApp?
