Refresh Clone failure with message "The Oracle base has been set to "
Applies to
SCO 4.8 and above
Issue
Refresh-SmClone command fails with sudo trying to get owner and group id for sqlplus command. The spl_*.log file from the failed job will show:
Execution Monitor Thread [sudo /opt/NetApp/snapcenter/spl/bin/sc_command_executor oracle "ls -ld '/orasw/oracle/product/19c/db/bin/sqlplus' | sed 's/[ ][ ]*/ /g' | cut -d' ' -f3"] c.n.c.e.ShellResult - EXE-00001: Shell result [0:00:00.118] (Exit Value: 0):
The Oracle base has been set to /orasw/oracle
oracle
This should result in just the single oracle value at the bottom.
