NetApp Knowledge Base
Oracle backup fails on SCO 6.0.1P1 scripts directory when pre- or post scripts are used
60
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
SCO 6.0.1P1 and 6.1 fail to find existing scripts directory
Applies to
SnapCenter Plug-in for Oracle 6.0.1 and higher
Issue
After upgrading from 6.0 to 6.0.1P1, the previously working backup using a pre-script now fails to continue and breaks off without a what appears to be a proper error.
From SnapManagerWeb_<JOB>.log, we find:
DEBUG SnapManagerWeb_1839007 PID=[3800] TID=[22] Updating the job (1839007) task (Finalizing Oracle Database Backup) status as Running
DEBUG SnapManagerWeb_1839007 PID=[3800] TID=[160] Updating the job (1839007) task (Pruning archive logs) status as Running
DEBUG SnapManagerWeb_1839007 PID=[3800] TID=[148] Updating the job (1839007) task (Pruning archive logs) status as Warning
DEBUG SnapManagerWeb_1839007 PID=[3800] TID=[159] Updating the job (1839007) task (Finalizing Oracle Database Backup) status as Failed
We also find:
Activity 'Prescripts' failed with error: Run pre scripts failed to execute. Pre script exited with script error code: -1, script error message: SPL-00010: Script directory /var/opt/snapcenter/spl/scripts does not exist.
New to NetApp?
