NetApp Knowledge Base
Point-in-time restore of Oracle database files fail with error: ORA-17503: ksfdopn:2 Failed to open file +DATADG_RACPDB_70/RACPDB/DATAFILE/control-bkp-1938271497.bkp
1,808
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
SnapCenter Plug-in 4.4 for Oracle Database
Issue
  • Point-in-time restore of Oracle database fails with error:
  • Activity 'Oracle Point In Time Recovery' failed with error:
PL-SCO-25000: Oracle Point In Time Restore of database files failed with error: com.netapp.oracle.core.platform.rman.RmanException: ORACLE-00101: Error executing RMAN command: [recover tablespace PDB:TS1 until scn 8937753 auxiliary destination '/mnt/auxDest' ;].  The command returned: ORA-19625: error identifying file +DATADG_RACPDB_70/RACPDB/DATAFILE/control-bkp-1938271497.bkp
ORA-15001: diskgroup "DATADG_RACPDB_70" does not exist or is not mounted
ORA-15040: diskgroup is incomplete
ORA-19600: input file is control file  (+DATADG_RACPDB_70/RACPDB/DATAFILE/control-bkp-1938271497.bkp)
ORA-19625: error identifying file +DATADG_RACPDB_66/RACPDB/DATAFILE/control-bkp-1938271497.bkp
ORA-17503: ksfdopn:2 Failed to open file +DATADG_RACPDB_66/RACPDB/DATAFILE/control-bkp-1938271497.bkp
ORA-15001: diskgroup "DATADG_RACPDB_66" does not exist or is not mounted
ORA-15064: communication failure with ASM instance
RMAN-00571: ===========================================================
RMAN-00569: =============== ERROR MESSAGE STACK FOLLOWS ===============
RMAN-03002: failure of recover command at 10/06/2020 15:25:08
RMAN-06136: Oracle error from auxiliary database:
RMAN-20202: Tablespace not found in the recovery catalog
RMAN-06019: could not translate tablespace name "TS1"
New to NetApp?
