NetApp Knowledge Base
How to clean up VMDK MPDisks and cloned (NFS) Datastores after SCW fails to do so
219
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
Applies to
  • SnapCenter Plug-in for SQL Server (SCSQL)
  • SnapCenter Plug-in for Windows (SCW)
  • SnapCenter Plug-in for VMware (SCV)
Basis: SQL Server installed inside a VM using VMDK virtual disks for the Database and Log files (and the Log Directory).
During verification, the process creates clones of the VMware datastores, and mounts the VMDKs inside the VM, usually under C:\scmnpt\ as mpdisk<NUM> mount directory. Any crash or other disruption can cause the process not to clean up these disks from the Windows VM, or the clones from the vCenter/vSphere.
The SnapCenter GUI still shows these MPDisk paths for the Host that cloned the original virtual disks from the Backup snapshot, which identifies the Host you need to go to for the initial clean-up part.
New to NetApp?
