Do Trident PVCs support Azure NetApp Files volumes smaller than 100GB?
Applies to
- Azure NetApp Files (ANF)
- Astra Trident 24.06
Answer
- At present, the latest Trident version (24.06) does not support ANF volumes smaller than 100GB, even though ANF introduced support for 50GB minimum volume sizes in August 2024.
- Trident PVC support for 50GB minimum ANF volume sizes is likely to be included in Trident version 25.02.
- If it is added sooner, it will be listed in the New Features section of the October / November 2024 release of Trident version 24.10.
