Can't restore in SnapCenter GUI from vault/mirror snapshot if not found on update
Applies to
SnapCenter Server
Issue
After the Backup Snapshot has been created on primary, either:
- the SnapMirror or SnapVault update could not be started (relationship not found/another transfer is still in progress), or
- the transfer took longer than the settings allow (normally 2 hours), timing out, not finding the snapshot on the destination
The Backup is not visible as being on the replication side (Mirror/Vault), and no restore can be done from it in SnapCenter GUI.
