Adding a Linux Host fails with "The key length should be greater than or equal to 2048 bits."
Applies to
- SnapCenter Plug-in for Linux (SCO/SCHANA/SCC) 4.2 and higher
Issue
When attempting to add a Host SnapCenter fails with:
The fingerprint key length of 1024 bits is less than the minimum supported key length of 2048 bits and is not secure.
