NetApp Knowledge Base
OnCommand Insight reports "HTTP 400 Bad Request" for EMC PowerStore data source
186
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
ds_dii
Last Updated:
Applies to
  • OnCommand Insight 7.3.13+
  • EMC PowerStore
Issue
OnCommand Insight reports "HTTP 400 Bad Request" for EMC PowerStore data sources running firmware 3.0.0.0+ but not EMC PowerStore data sources running older firmware versions.
ASUP_<Sitename>_1678143020708/acq/foundation_<DataSourceName>_1258_2023_03_06_08_24_28_610/root\log_sample.log
2023-03-06 08:24:28,610 ERROR [com.onaro.sanscreen.acquisition.framework.datasource.BaseDataSource] DataSourceName [Error retrieving data] - Request failed with status 400 : https://<IP Address>:443/api/rest/node?offset=0&limit=2000&select=appliance%2Cappliance_id%2Cid%2Cname%2Cip_pool_addresses%2Cslot%2Cveth_ports ([Device name General Device]: Request failed with status 400 : https://<IP Address>:443/api/rest/node?offset=0&limit=2000&select=appliance%2Cappliance_id%2Cid%2Cname%2Cip_pool_addresses%2Cslot%2Cveth_ports)
com.onaro.sanscreen.acquisition.util.stream.http.JsonRestResponseException: Request failed with status 400 : https://<IP Address>:443/api/rest/node?offset=0&limit=2000&select=appliance%2Cappliance_id%2Cid%2Cname%2Cip_pool_addresses%2Cslot%2Cveth_ports
New to NetApp?
