NetApp Knowledge Base
OCI health page reports Anomaly Detection Engine: "ERROR: Failing to monitor job(s)"
328
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
Applies to
  • OnCommand Insight (OCI) 7.3.8+
  • Anomaly Detection Engine (ADE)
Issue
  • OCI health page reports Anomaly Detection Engine: "ERROR: Failing to monitor job(s)"
  • The following output may be present in the prelet.log located at <install_drive>Program Files\SANscreen\wildfly\standalone\log
2020-04-07 09:03:09,572 ERROR PrelertRetryUtil - Failure of attempt 1 of request of type FLUSH_ML_JOB following delay of 0 milliseconds. Request will be tried again after delay of 0 milliseconds.
java.util.concurrent.ExecutionException: org.apache.http.ConnectionClosedException: Connection closed
[truncated]
2020-04-07 09:03:09,614 ERROR PrelertRetryUtil - Failure of attempt 2 of request of type FLUSH_ML_JOB following delay of 0 milliseconds. Request will be tried again after delay of 4000 milliseconds.
java.util.concurrent.ExecutionException: java.net.ConnectException: Connection refused
[truncated]
2020-04-07 09:03:44,578 ERROR PrelertClient - Failed to add data to Anomaly Detection Engine for <job_name>. Http status response: HTTP/1.1 409 Conflict.
  • The output of the below command from the ADE cli will report at least one failed job.
curl -X GET "localhost:9200/_xpack/ml/anomaly_detectors/_stats?pretty"
[truncated]
"state" : "failed",
"assignment_explanation" : ""
[truncated]
New to NetApp?
