OCI EMC datasource fails with error: Failed to login to SMI-S provider at
Applies to
- OnCommand Insight 7.3.4 (OCI)
- EMC Symetrix datasource
Issue
- Cannot collect performance data from EMC symetrix datasource with error:
Failed to login to SMI-S provider at s00v09961398:5989/interop as user:admin
Performance error message :
Failed to execute Sym CLI symsan, because <?xml version="1.0" standalone="yes" ?> <SymCLI_ML> <Symmetrix> array_id </id> <port_record> <local_dir>01D</local_dir> <local_port>04</local_port>
<vendor>EMC Symmetrix</vendor> <array_id> array_id </array_id> <lun_count>1</lun_count> <port_wwn>port_wwn</port_wwn> </port_record> <port_record> <local_dir>01D</local_dir>
<local_port>05</local_port> <vendor>EMC Symmetrix</vendor> <array_id>array_id</array_id> <lun_count>1</lun_count> <port_wwn>port_wwn</port_wwn> </port_record> <port_record>
<local_dir>01D</local_dir> <local_port>08</local_port> <vendor>EMC Symmetrix</vendor> <array_id>array_id</array_id> <lun_count>1</lun_count> <port_wwn>port_wwn</port_wwn> </port_record>
<port_record> <local_dir>01D</local_dir> <local_port>09</local_port> <vendor>EMC Symmetrix</vendor> <array_id>array_id</array_id> ... [ Full content in recording file ]
- in the datasource recording archive we see under
foundation_<datasource_id>\<recording_id>\recording_sysman_<array_id>.txt
file, at the bottom:
All available SYMSAN resources are currently in use. Please try again later
</The tag "</SymCLI_ML>" did not match the expected "</Symmetrix>".
Error: XML parser error in state 8, found type 10.
