NetApp Knowledge Base
How to save Data Warehouse IBM Cognos reports to a network drive for DWH 7.3.3 and later
239
Visibility:
Votes:
0
Category:
oncommand-insight-data-warehouse
Specialty:
oci
Last Updated:
Applies to
OnCommand Insight DataWarehouse (DWH) 7.3.3 and later
  • As part of keeping DWH healthy, it is recommended to keep the Cognos database under 200MB. If Cognos reports are saved to the database, this can cause the database to grow significantly and cause issues with backing up and restoring the reporting database, or cause reporting database corruption.
  • To avoid saving the report outputs to the database, configure Cognos to use a local or network location.
New to NetApp?
