NetApp Knowledge Base
DII ONTAP ZAPI data collector generates excessive audit log entries on ONTAP cluster
63
Visibility:
Votes:
0
Category:
data-infrastructure-insights
Specialty:
oci
Last Updated:
Applies to
  • Data Infrastructure Insights (DII)
  • NetApp ONTAP Data Management Software data collector (ZAPI-based)
  • ONTAP 9.17.1 and later
Issue
After installing the Data Infrastructure Insights (DII)ONTAP data collector (ZAPI-based) on an ONTAP cluster,
the ONTAP audit log generates a high volume of entries attributed to the DII collector user account.
Symptoms include:
  • Tens of thousands of audit log entries per day (e.g., ~65,000/day) from the DII collector user
  • Audit log entries showing "Insufficient privileges:  user '<username>' does not have write access to this resource" for aggr-check-spare-low ZAPI
  • Audit log entries showing "authentication failed" from "unknown:unknown" for ZAPI calls, even when the DII collector login succeeds (HTTP 200)
  • Data collection in DII completes successfully with no errors reported in the DII console
  • Audit log signal-to-noise ratio is degraded, making it difficult to identify legitimate security events
Example audit log entries:
aggr-check-spare-low :: Error: Insufficient privileges:
resource
authentication failed from unknown:unknown
(ONTAPI/ZAPI call)
New to NetApp?
