Acquisition fails for NetApp Clustered Data ONTAP data source in OCI with internal error
Applies to
- OnCommand Insight 7.3.x SP10 and bellow (OCI)
- ONTAP 9.x
Issue
- The acquisition of the cdot cluster is failing in OCI because of null pointer exception.
- Error seen in the
acq.logand on the foundation recording folder under.../root/log_sample.logof the error report:
2021-09-13 12:50:45,274 FATAL [com.onaro.sanscreen.acquisition.framework.datasource.BaseDataSource] [foundation] <Cluster name> - Runtime exception: null
java.lang.NullPointerException: null
at java.util.TreeMap.getEntry(TreeMap.java:347) ~[?:1.8.0_271]
at java.util.TreeMap.containsKey(TreeMap.java:232) ~[?:1.8.0_271]
2021-09-13 12:50:45,274 ERROR [com.onaro.sanscreen.acquisition.framework.datasource.BaseDataSource] <cluster name> [Internal error] - Error (Error)
com.onaro.sanscreen.acquisition.framework.datasource.DataSourceErrorException: Error
at com.onaro.sanscreen.acquisition.framework.datasource.DataSourceErrorException.createWithEnhanced(DataSourceErrorException.java:67) ~[au.jar:?]
Caused by: java.lang.NullPointerException
