AIQDA Health Check shows spares low alert despite no callhome.spares.low in EMS
Applies to
- Active IQ Digital Advisor (AIQDA)
- ONTAP 9
Issue
- The following alert appears in Capacity on Dashboard in AIQDA and disappears after a few days:
Impact: MediumMitigation: Potentially Non-disruptiveCategory: StorageCorrective Action: Why am I getting a SPARES LOW warning?
What sparing criteria does the 'Low number of spare disks' healthcheck use?Impact Area: CapacityObject Type: DISKRisk: Low number of spare disks.Potential Impact: If there aren't enough spares, in the event of a failure, a reconstruct will not be kicked off and redundancy will be affected.Details: There are not enough X336 partition 2 drives available in this storage appliance.
- The same alert remains in Spares & Drives on Recommended Configuration on Health Check in AIQDA
- There are no drive issues on ONTAP side, and
callhome.spares.lowis not recorded in EMS SYSCONFIG-Rin AutoSupport for the target node of the alert shows that the node has only a root aggregate and a spare partition:
Aggregate node2_aggr0 (online, raid_dp) (block checksums)
Plex /node2_aggr0/plex0 (online, normal, active, pool0)
RAID group /node2_aggr0/plex0/rg0 (normal, block checksums)
RAID Disk Device HA SHELF BAY CHAN Pool Type RPM Used (MB/blks) Phys (MB/blks)
dparity 0a.00.10P2 0a 0 10 SA:A 0 FSAS 7200 63849/130764288 63857/130780672
parity 0a.00.2P2 0a 0 2 SA:A 0 FSAS 7200 63849/130764288 63857/130780672
data 0a.00.4P2 0a 0 4 SA:A 0 FSAS 7200 63849/130764288 63857/130780672
data 0a.00.6P2 0a 0 6 SA:A 0 FSAS 7200 63849/130764288 63857/130780672
data 0a.00.8P2 0a 0 8 SA:A 0 FSAS 7200 63849/130764288 63857/130780672
Pool1 spare disks (empty)
Pool0 spare disks
Spare disks for block checksum
spare 0a.00.0P2 0a 0 0 SA:A 0 FSAS 7200 63849/130764288 63857/130780672
