NetApp Knowledge Base
Lost the AQUIM connection to a NetApp node with SQLite errors
119
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
4/2/2025, 4:57:01 PM
Applies to
  • ONTAP 9
  • Active IQ Unified Manager
Issue
  • System Manager is getting hung while loading and goes into unresponsive state.
  • From logs, we get below messages:
AUDIT-MLOG-TXT.GZ
Wed Jan 01 2023 00:00:00 +02:00 [kern_audit:info:11111] 1234e8000001f000 :: Cluster1:ontapi :: 192.168.0.1:11111 :: Cluster1:admin :: POST /servlets/netapp.servlets.admin.XMLrequest_filer HTTP/1.1 :: Error: 502 Proxy Error
APACHE-ERROR.GZ
[Wed Jan 01 10:00:00.111111 2023 +0000] [proxy:error] [pid 95609:tid 34402477568] [client 192.168.0.1:54858] AH00898: Error reading from remote server returned by //servlets/netapp.servlets.admin.XMLrequest_filer
[Wed Jan 01 10:00:00.111112 2023 +0000] [proxy_  http:error] [pid 95609:tid 34402477568] (20014)Internal error (specific information not available): [client 192.168.0.1:54858] AH01102: error reading status line from remote server 127.0.0.1:936
MGWD.GZ
Wed Jan 01 10:00:00 +02:00 [kern_mgwd:info:3153] A [src/rdb/sql_local_unit.cc 806 (0x823d02000)]: sqlite_logger: SQLite Error: (1) statement aborts at 4: [ATTACH DATABASE '/mroot/etc/cluster_config/rdb/VLDB/_sql/rdb.db' AS vldb;] database vldb is already in use
Wed Jan 01 10:00:00 +02:00 [kern_mgwd:info:3153] 0x823d02000: 8803eb00002a49c4: ERR: SQL_CONTEXT: _execute_setup_stmts:src/sql_context.cc:1056 _execute_setup_stmts: failed to exec statement 'ATTACH DATABASE '/mroot/etc/cluster_config/rdb/VLDB/_sql/rdb.db' AS vldb;' for on demand connection 0x834cabd08: SQL logic error database vldb is already in use
Wed Jan 01 10:00:00 +02:00 [kern_mgwd:info:3153] sqlite exec message: database vldb is already in use
Wed Jan 01 10:00:00 +02:00 [kern_mgwd:info:3153] A [src/rdb/sql_local_unit.cc 806 (0x821a39c00)]: sqlite_logger: SQLite Error: (1) statement aborts at 4: [ATTACH DATABASE '/mroot/etc/cluster_config/rdb/Bcom/_sql/rdb.db' AS bcomd;] database bcomd is already in use
Wed Jan 01 10:00:00 +02:00 [kern_mgwd:info:3153] 0x821a39c00: 8503e80002080bc0: ERR: SQL_CONTEXT: _execute_setup_stmts:src/sql_context.cc:1056 _execute_setup_stmts: failed to exec statement 'ATTACH DATABASE '/mroot/etc/cluster_config/rdb/Bcom/_sql/rdb.db' AS bcomd;' for on demand connection 0x834cabd08: SQL logic error database bcomd is already in use
Wed Jan 01 10:00:00 +02:00 [kern_mgwd:info:3153] sqlite exec message: database bcomd is already in use
New to NetApp?
