NetApp Knowledge Base
Is it possible to display a volume’s capacity graph in the AIQUM GUI for an arbitrary time range?
6
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
ActiveIQ Unified Manager(AIQUM)
Answer
No, the volume capacity graph in the AIQUM GUI can only be displayed using fixed, predefined time ranges (1 Week / 1 Month / 1 Year).
Additional Information
Volume / Health details page - You can select a graph type from the drop-down list at the top of the History pane. You can also view details for a specific time period by selecting either 1 week, 1 month, or 1 year. History graphs can help you identify trends: for example, if large amounts of data are being transferred at the same time of the day or week, or if the lag warning or lag error threshold is consistently being breached, you can take the appropriate action. Additionally, you can click the Export button to create a report in CSV format for the chart that you are viewing.
