NetApp Knowledge Base
Gap observed in AIQUM Performance Graph for Single Node
46
Visibility:
Votes:
0
Category:
not set
Specialty:
not set
Last Updated:
This knowledge base was generated through a script and may contain formatting issues. For the accurate content, please refer to the WIP editor. WIP editor.
Applies to
  • Active IQ Unified Manager (AIQUM) 9.x
  • ONTAP 9.x (Cluster-Mode)
  • NetApp AFF and FAS systems
Issue
Active IQ Unified Manager (AIQUM) did not display performance graph data for a specific node for approximately a 25-minute interval between 12:00 PM and 1:00 PM IST on 16th September. Other nodes in the same cluster showed complete data for this period.
Example Log Output:
[kern_mgwd:info:3708] ERR: job_manager::rdb_util:create_rw_transaction: ... Failed to get transaction. Node "*****" on ring "Management" is offline. Check the health of the cluster using the "cluster show" command. For further assistance, contact technical support. (393271)
ERR: Tables:web:web_proxy_cluster_lifs: mgmt is offline on node ******
DEBUG: WAFL_ENC::ROOT: online_status_callback RDB unit is offline.
New to NetApp?
