NetApp Knowledge Base
Adding ONTAP 9.14.1 and above Cluster to AIQUM 9.14 and above fails when SAML is enabled on the cluster
1,042
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
  • Active IQ Unified Manager (AIQUM) 9.14+
  • ONTAP 9.14.1Px and above
  • SAML Configuration
Issue
  • Adding, modifying or removing a cluster to AIQUM  fails with an exception if SAML is enabled on the cluster
  • Error:
ERROR [umadmin] [default task-166] [c.n.d.o.o.OntapMutualAuthenticationManager] Exception installing Mutual TLS certificate on ONTAPcom.google.gson.JsonSyntaxException: com.google.gson.stream.MalformedJsonException: Use JsonReader.setLenient(true) to accept malformed JSON at line 1 column 13 path $
New to NetApp?
