AIQUM Health view fails for Metroclusters due to stale MetroCluster partner ID present on backend
Applies to
- Active IQ Unified Manager 9.x(AIQUM)
- MetroCluster via IP
Issue
- Opening the cluster Health view in AIQUM for a metrocluster fails:
Unable to find com.netapp.dfm.entity.inventory.ontap.fas.Cluster with id <missing_cluster_id>
- The dialog reports that no details are available and that no suggested corrective action is available.
ocumserver.logrecords the same failure:ERROR [admindsi] [default task-35] [service.fas.cluster.ClusterDataAccessService|loadSummary] [org.dozer.util.LogMsgFactory] An exception occurred invoking toString() on the source field value: com.netapp.dfm.entity.inventory.ontap.fas.Cluster$HibernateProxyjakarta.persistence.EntityNotFoundException: Unable to find com.netapp.dfm.entity.inventory.ontap.fas.Cluster with id <missing_cluster_id>at deployment.dfm-app.war//org.hibernate.jpa.boot.internal.EntityManagerFactoryBuilderImpl$JpaEntityNotFoundDelegate.handleEntityNotFound(EntityManagerFactoryBuilderImpl.java:192)at deployment.dfm-app.war//org.hibernate.proxy.AbstractLazyInitializer.checkTargetState(AbstractLazyInitializer.java:304)......ERROR [admindsi] [default task-35] [service.fas.cluster.ClusterDataAccessService|loadSummary] [org.dozer.MappingProcessor] Field mapping error -->MapId: nullType: nullSource parent class: com.netapp.dfm.entity.inventory.ontap.fas.ClusterSource field name: mccDrPartnerClusterSource field type: class com.netapp.dfm.entity.inventory.ontap.fas.Cluster$HibernateProxySource field value: Unable to determine source field valueDest parent class: com.netapp.dfm.webui.shared.dto.fas.ClusterSummaryDtoDest field name: mccDrPartnerClusterDest field type: com.netapp.dfm.webui.shared.dto.ManagedObjectReferenceDtojakarta.persistence.EntityNotFoundException: Unable to find com.netapp.dfm.entity.inventory.ontap.fas.Cluster with id <missing_cluster_id>
