NetApp Knowledge Base
osc tcp connectFailed event occurs intermittently
13
Visibility:
not set
Votes:
0
Category:
not set
Specialty:
not set
Last Updated:
Applies to
  • * Cloud Volumes ONTAP for AWS
  • * Object storage
  • * Cloud Tiering
Issue
* The following event intermittently occurs.
> > osc.tcp.connectFailed: TCP connection to object store server hostname
> > 'XX-XX-XXXX.amazonaws.com' fails over IP address 'XX.XX.XX.XX' on node
> > 'XXXX'.
* "Object.store.unavailable" event doesn't occur.
* Cloud tiering is healthy.
New to NetApp?
