NetApp Knowledge Base
NFS Kerberos Authentication Fails with Cross Domain Users
Visibility:
not set
Votes:
0
Category:
not set
Specialty:
not set
Last Updated:
Applies to
  • * NFS Kerberos (krb5) authentication
  • * Multi-domain Active Directory environments
Issue
When mounting an NFSv4.1 volume with Kerberos authentication (sec=krb5) from a
client joined to a different domain within the same Active Directory forest, the
mount fails with:
mount.nfs4: access denied by server while mounting :/_x000D_
ONTAP logs show:
secd.nfsAuth.problem: vserver() General NFS authorization problem. Error: RPC accept GSS token procedure failed_x000D_
[2] Mapping Successful for SPN 'ELKSDXNFT15DTE8$@SDX.PAYROC.DEV' to UNIX user 'ELKSDXNFT15DTE8$'_x000D_
[5] Entry for user-name: ELKSDXNFT15DTE8$ not found in the current source: FILES. Ignoring and trying next available source_x000D_
[73] FAILURE: User 'ELKSDXNFT15DTE8$' not found in UNIX authorization source LDAP._x000D_
[73] Unable to map SPN 'ELKSDXNFT15DTE8$@SDX.PAYROC.DEV'_x000D_
[73] Unable to map Kerberos NFS user 'ELKSDXNFT15DTE8$@SDX.PAYROC.DEV' to appropriate UNIX user_x000D_
[75] Failed to accept the context: The routine completed successfully (minor: Unknown error). Result=6916_x000D_
New to NetApp?
