FAN is spinning too slow on FAS70 even after replacing the FAN
This knowledge base was generated through a script and may contain formatting issues. For the accurate content, please refer to the WIP editor. WIP editor.
Applies to
FAS70
Issue
- Sensor F2 of SysFan 5 was spinning too slow.
EMS-LOG-FILE.GZ[NODE:env_mgr:monitor.chassisFan.degraded:alert]: Chassis fan is degraded: Sysfan5F2 Speed is spinning too slow (900 RPM)[NODE:statd:monitor.fan.failed:alert]: One fan has failed: Sysfan5F2.[NODE:env_mgr:callhome.c.fan.fru.fault:error]: Callhome for CHASSIS FAN FRU FAILED: Sysfan5F2 Speed
PLATFORM-SENSORS.XMLSysfan5 F1 Speed fan normal 11100 RPM 2000 3000 18000 20000Sysfan5 F2 Speed fan crit-low 900 RPM 2000 3000 18000 20000Bad Fan Bitmap unknown crit-high 512 -1 1Sysfan5 F1 discrete normal normal GOOD Sysfan5 F2 discrete fault normal BAD
SP-LATEST-IPMISysfan5 Status normal 9 -- -- -- -- Sysfan5 Present PRESENTSysfan5 F1 Speed normal 11100 RPM 2000 RPM 3000 RPM 18000 RPM 20000 RPM Sysfan5 F2 Speed critlow 900 RPM 2000 RPM 3000 RPM 18000 RPM 20000 RPM Bad Fan Bitmap crithigh 512 -1 -- -- 1
- Fan was replaced, yet the issue persisted.
