NetApp Knowledge Base
Cannot Enable AES Encryption With Error KRB5 KDC UNREACH in ONTAP 9
58
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
  • ONTAP 9
  • CIFS/SMB
  • Kerberos
  • AES Encryption
Issue
  • When trying to enable AES Encryption for the vserver, the process fails with error KDC unreachable:
    • ::> vserver cifs security modify -vserver svm01 -advertised-enc-types
      aes-128,aes-256
      Info: In order to disable CIFS AES encryption, the password for the CIFS server
      machine account must be reset. Enter the
      username and password for the CIFS domain "DOMAIN.LOCAL".
      Enter your user ID: administrator
      Enter your password:
      Error: command failed: Password update failed. Reason: Kerberos Error: KDC
      unreachable.
  • SECD logs show failures in communication through port 464 with error (KRB5_KDC_UNREACH):
    • ERROR secd.unexpectedFailure: Unexpected SecD failure in Vserver "svm01".
      Details: Error: CIFS server password change procedure failed
      [ 21 ms] Successfully connected to ip 172.11.111.11w, port 389 using TCP
      [ 38] Successfully connected to ip 172.11.111.11w, port 88 using TCP
      [ 2047] TCP connection to ip 172.11.111.11w, port 464 failed: Operation timed
      out.
      [ 4050] TCP connection to ip 172.11.111.11x, port 464 failed: Operation timed
      out.
      [ 6506] TCP connection to ip 172.11.111.11y, port 464 failed: Operation timed
      out.
      [ 8003] TCP connection to ip 172.11.111.11z, port 464 failed: Operation timed
      out.
      [14084] FAILURE: Kerberos password change for 'SVM01$@DOMAIN.LOCAL.COM' failed
      with Cannot contact any KDC for requested realm (KRB5_KDC_UNREACH)
      [14084] Retry requested, but the retry window (7000 ms) has expired; giving up.
New to NetApp?
