ANDU task failed
Applies to
- 9.14.1P15
Issue
Upgrade task failed while trying to delete and re-add custom REST role access control entries with "/api/security/roles" endpoint.
upgrade-revert show -node
Status Message: The upgrade failed. Contact support personnel for the upgrade repair procedure.
Vers Phase Status Upgrade Phase Status Message
1100 pre-root applied No upgrade is required for this phase.
1100 pre-apps applied Upgrade successful.
1100 post-apps applied Upgrade successful.
1400 pre-root applied No upgrade is required for this phase.
1400 pre-apps applied Upgrade successful.
1400 post-apps applied Upgrade successful.
1600 pre-root applied No upgrade is required for this phase.
1600 pre-apps applied No upgrade is required for this phase.
1600 post-apps applied Upgrade successful.
2400 pre-root applied No upgrade is required for this phase.
2400 pre-apps applied Upgrade successful.
2400 post-apps failed This upgrade phase has one or more failure task.
12 entries were displayed.
