NetApp Knowledge Base
CONTAP-149463: DR CONFIG REPLICATION FAILED - Error: Schedule not found
363
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
6/13/2025, 3:43:03 PM
Issue
DR CONFIG REPLICATION FAILED autosupport message is received with error messages:
Failed Reason: Unrecoverable error during configuration replication, requires manual intervention. Error: Schedule <missing_schedule> not found. One or more job schedules are missing from the remote cluster. Run "job schedule show" on both clusters to view the schedules.
ClusterA::> metrocluster check cluster show
 Last Checked On: 1/23/2020 07:15:00
Cluster               Check                                Result
ClusterB
                      negotiated-switchover-ready          not-applicable
                      switchback-ready                     not-applicable
                      job-schedules                        warning
                      licenses                             ok
                      periodic-check-enabled               ok
                      onboard-key-management               ok
                      external-key-management              ok
ClusterA
                      licenses                             ok
14 entries were displayed.
ClusterA::> metrocluster check cluster show -instance
                        Type of Check: job-schedules
                         Cluster Name: mcc8n-rtp-1a
                  Result of the Check: warning
Additional Information/Recovery Steps: One or more job schedules are missing from the remote cluster. Run "job schedule show" on both clusters to view the schedules.
New to NetApp?
