NetApp Knowledge Base
CONTAP-153137: Automated NDU operations, such as package get or delete and update, can fail
61
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
4/2/2025, 3:23:36 PM
Issue
The ANDU commands, such as 'cluster image show-update-progress', 'cluster image package get', and 'cluster image package delete' can fail with the following errors:
  • Both primary and backup images should be available for validation,
    one or both of them are not available.
  • Package delete timed out on Node <node-name> and the package will be
    deleted when the node recovers.
  • Expecting at least two active nodes to store the package, found one active
    node, exiting. Make sure the cluster has two active nodes before getting the
    package again.
  • The node where the package is being stored is unavailable.
  • Failed to delete package because it does not exist on the system.
New to NetApp?
