NetApp Knowledge Base
Unable to add E-Series data collector to DII due to network issues
11
Visibility:
Votes:
0
Category:
data-infrastructure-insights
Specialty:
cloud
Last Updated:
Applies to
  • NetApp Data Infrastructure Insights (DII)
  • NetApp E-Series Storage Arrays
Issue
  • When attempting to add E-Series device to the DII monitoring system, the following errors appear in the data collector logs:
E-Series Example Log:
ERROR [com.onaro.sanscreen.acquisition.datasource.engenio_santricity_api.transport.EngenioManagementPath] Could not open address mgxxxxx.axx.int, Connection refused: connectjava.net.ConnectException: Connection refused: connect...ERROR [com.onaro.sanscreen.acquisition.framework.datasource.AuditSession] Failed to connect to device
  • While adding the collector, using the Test Connection button gives
Configuration: Successfully pinged <controller1_ip>.
Configuration: Successfully pinged <controller2_ip>.
Cannot connect to host - Connection Refuse
  • Verify and enable the required network ports between the DII Acquisition Unit and the E-Series :
  • E-Series Legacy SANtricity API: TCP 2463
  • E-Series REST API: HTTPS 8443
  • Confirm connectivity from the DII Acquisition Unit to the management addresses of the target devices using the following tests:
  • ping
  • nslookup
  • port connectivity tests (e.g., Test-NetConnection or telnet) to the required ports
    New to NetApp?
