NetApp Knowledge Base
DII fail to monitor storage grid data collector with SSO enabled
48
Visibility:
Votes:
0
Category:
data-infrastructure-insights
Specialty:
ds_dii
Last Updated:
Applies to
  • Storage Grid/E-Series Data collector
  • Data Infrastructure Insights (DII)
Issue
  • Storage Grid data collector fails to collect data via SSO authentication method via Azure Entra ID
  • Works immediately when changed to Basic Auth
  • Direct login to storage grid via Azure Entra ID user used in DII works fine
  • Error in the GUI as well as when performed Test Connection is: Failed to execute request: POST HTTP/1.1.
  • log_samlple.log from recording files:
ERROR [com.onaro.sanscreen.acquisition.framework.datasource.BaseDataSource] StorageGrid_NetApp [Error connecting] - Failed to execute request: POST  HTTP/1.1 ([Device name https://<storage_grid_IP>:443]: Failed to execute request: POST  HTTP/1.1)
com.onaro.sanscreen.acquisition.framework.datasource.DataSourceErrorException: Failed to execute request: POST  HTTP/1.1
at com.onaro.sanscreen.acquisition.framework.datasource.DataSourceErrorException.createWithoutEnhanced(DataSourceErrorException.java:81) ~[au.jar:1.855.0]
at com.onaro.sanscreen.acquisition.util.stream.http.HttpClient.newBadResponseException(HttpClient.java:667) ~[netapp_storagegrid_as_storage.jar11606646094374642102.jar:?]
Caused by: org.apache.http.client.ClientProtocolException
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:187) ~[httpclient-4.5.14.jar:4.5.14]
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83) ~[httpclient-4.5.14.jar:4.5.14]
at com.onaro.sanscreen.acquisition.util.stream.http.HttpClient.executeLive(HttpClient.java:593) ~[netapp_storagegrid_as_storage.jar11606646094374642102.jar:?]
... 23 more
Caused by: org.apache.http.ProtocolException: Target host is not specified
ERROR [com.onaro.sanscreen.acquisition.framework.datasource.AuditSession] Failed to execute request: POST  HTTP/1.1
org.apache.http.client.ClientProtocolException: null
New to NetApp?
